Lowering also can help. A lower center of gravity helps handling, and they are pretty tall stock. There are dropped uprights available.
Springs and a sway bar tuned to modern rubber will help too. Just depends on how much you want to change and spend.
Here's a lot of good info, make sure to read the article about half way down.
http://shadowmtkustomz.blogspot.com/
