My car was doing something similar. The lights would flicker noticably while driving, would dim really bad at stoplights. It finally blew out a fusible link. Found out there was an internal short/ground inside the alternator when I got it tested. Replaced the fusible link and alternator and all symptoms are cured.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
