Here is a pic of the passenger side rear frame rail. You can see more rot around the e-brake cable bracket. The other frame rail is in similar shape. Based on the pic seen here, would you replace both rear frame rail with replacement rails from AMD, or attempt some sort of repair job, cutting out rust/rot and patching in new steel? Keep in mind I'm not looking for a trailer queen, just a nice fair weather driver.
Replace or repair rear frame rails?
multiple choice, up to 2 choices
Votes accepted starting: 10/17/09 05:16 PM
You must vote before you can view the results of this poll.
