The carb choice is your preference.I would run 600 cfm what ever you choose.It won't hurt you now and will support upgrades later. Honestly I think dual exhaust will help more than a 4 barrell.Be prepeared to re-tune it after you swap exhaust. At a minimum I would install a high flow muffler even with single exhaust.Stock (quiet) mufflers are very restrictive.
