This is a great question. My Challenger is at the bodyshop right now. They were planning on doing some test sprays of different colors to find one that matched the front fillers the best. If anyone knows of a different solution let us know. Even if the paint matches pretty good, you will still be able to tell that it is painted.
I always just assumed that the Cuda rear fillers were sprayed organisol like the tail panel but I guess not. The Challenger rear fillers are sprayed with argent paint so that isn't an issue. Just the fronts are natural on the Challengers.
