The 440 is taller and wider than the 383 also. Think your stock exhaust will still bolt up even with the stock logs? Do yourself a favor. Do it right the first time. It'll be cheaper in the long run.
Im hoping wthe exhaust will have enough flexibility to mount up to the 440. As explained above cost is an issue all at one time.
