You can put one in, but you should move the spring perches as they are a bit too far apart. It will also cause the need to run wheels with lots of back spacing to clear the wheelwells. Stock wheels are a no-go unless your scamp is actually a Duster or Demon/Dart sport. If you are going to a more modern size wheel (17" & up), back spacing isn't really an issue since most are like that anyway. If all you want is the bolt pattern, you would be better off to get a later "undesireable" 8 1/4" A body axle.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
