Re: Alky guys, Where do you put your lean out valve?
[Re: cudabin]
#483664
09/30/09 09:32 AM
09/30/09 09:32 AM
Posts: 642 New Jersey
Craig
New Jersey
Arnie, with injection you should use the shutoff valve to lean it after it has started. To build heat I inch it out until I just hear some popping in the exhaust, that is close to stalling it, and usually gets me 2500 rpm. I use a cable from a semi truck that I can rotate the knob for a very fine adjustment, its really handy: http://www.awdirect.com/exterior-throttle-cable-15-foot-control-cable-vcgtx15/throttle/
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
Entire Thread
Hunted Duck
09/29/09 09:36 PM
MegaDart
09/29/09 10:25 PM
WILD BILL
09/29/09 11:46 PM
GORacing
09/30/09 02:11 AM
WILD BILL
09/30/09 02:28 AM
cudabin
09/30/09 03:07 AM
MegaDart
09/30/09 11:15 AM
Craig
09/30/09 01:32 PM
cudabin
09/30/09 02:29 PM
MegaDart
09/30/09 05:03 PM
68roadrunner
09/30/09 12:44 AM
GORacing
09/30/09 02:09 AM
