I am installing an addco rear sway bar in my 73 Charger and it doesn't fit right with the provided hardware. I have the wheels off and jack stands under the axle at normal ride height. My problem is that the middle links do not meet up to the frame, they are too far away and if I raise it to get close enough the end links hit the axle. Has anybody else installed one of these. This will be the last Addco product I ever buy I had a similar problem with their front sway bar.
Pictures
This is with the shorter bolts they supply, I can't even get it close to the frame
This is with the longer bolts and spacer, I cant even get all the bushings in because the bar hits the frame and rearend.
