Quote: so would i put both AA' batterys next to each other and then one wire from the + sides and another wire from the negative sides?
no that would be a parallel circuit which would double the amps but keep the voltage the same (1.5V). You want to put one battery on top of the other (series) which doubles the voltage (to 3 volts)& keeps the amperage the same.
