set it yourself and no worries.
put your weight in barbells in the drivers seat on a level surface, tires aired up, a 1/2 tank of gas: adj each side to where a reference point (LCA to subframe) is the same side to side AND the the tire/wheel looks good in the wheel well and jounce it after each time you crank it some more. It can be any height that you feel comfortable with (within reason). tell the shop that you have the height set where you want it & not to touch it. I gotta ask what is CRS.
