The best way is to take a 2" long X 6"round piece of pipe & weld it to the spring pocket on the bottom of the lca. Take a torch or a plasma cutter & cut the pocket out from the inside. Weld 4 angle iron tabs to the bottom of the pipe & weld the piece that you cut with the torch inside the pipe. Use the pieces of angle to weld braces to.
Got pics?
How about this??
Nice job! I bet you could sell afew of those
