Check your compression tester, it should have a check valve in it so the gauge stays at the highest reading until you release the pressure manually. I found when I tried my comp tester it was leaking down so I had to redo the gauge connection on it with teflon tape. Now the reading doesn't leak down anymore and the cylinders read 10psi higher.
