boy that's going to be hard. I guess you could always go with a Paxyon "carb box" instead of a bonnet. That might help w/ the height. A good carb bonnet is going to be about 3" taller than the carb. Do you have 3"'s to spare w/ that intake? You might also have to cut some of your hood supports. You should probably use a junky stock hood to check 1st.
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
