I like it. It looks like mine. You should be fine seeing the tree. Just be careful in the pits .
Im glad i will be able to see the tree. I was thinking i was gunna always have to run the right lane.
Shawn as long as you get that 8 whats it matter what lane you do it in.Good luck .
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
