what motor in car out motor assemble what cam??
I would clean it and apply lube to bearings in block and on cam once in block coat lobes liberally with lube before lifters go in!
its a 340 block stroked to 416. the motor is out of the car and right now assembled up to the cam. the cam is a flat tappet from comp cam.
what should i use to clean the cam? i dont want to use a product that will make the lube not wanna stay on it at all....
Im goin fast Mom!
