Quote:Quote:Quote:Quote:Probably no gain unless you unshroud the valve by machining the combustion chamber. if that is shrouded, you can expect very little then bore size comes into play.imo... Anytime I've tried unshrouding the intake valve (straight wall side) on an OEM head, it hurt flow. I haven't tried it on the RPM though. That is interesting,Have only seen the opposite.
