Hi,
thanks for the feedback.
The oil looks fine. Golden as usual, there is also no oil in the water. I will check the spark plug. Despite from using water it runs strong on all eight cylinders and doesn't make any problem.
The engine is one of the first new ones from 1996. I mixed it up, it isn't a crate engine which was built by mopar. It was just a new block. Then engine was built overhere to stock specifications.
Carsten
