Where can I pickup the ohio crank I beams and whats the cost
you can pick them up from ohio crankshaft.
it would be wise to have your machinist disassemble them, reassemble, stretch the bolts to spec. for whatever bolts they come with and then check them for size and roundness.
DAMHIK
