here's an easy test pump the gas 2 full times and see if it does it.
Have to agree.. the current motor in my car does it now and you pump it and it turns over smooth.. My solution however is that this engine is coming out, so...
So is this a lean start condition?
ummmm yes, did you read my post it is a possibility.
