Re: engine builders, bearing clearance?
[Re: 440Jim]
#458667
09/06/09 11:04 AM
09/06/09 11:04 AM
Posts: 877 ky
68roadrunner
ky
if i go .003 on rods and mains both, and run a 50w or 20-50 oil this will be ok on a bracket motor? thanks guys
That does seem like a lot for the rods. Are you running steel rods or aluminum? Are they 2.200" or 2.375" journals? It will give more oil flow to the rods for cooling.
I wouldn't run straight 50 oil on a "mild" bracket motor unless you have a good reason. 20W-50 would be fine, IMO.
steel eagle, 2.375 i suppose at .0025 i would be closer to the .001 per inch rule.
Entire Thread
68roadrunner
09/04/09 01:00 AM
09/04/09 01:58 AM
68roadrunner
09/04/09 02:16 AM
Cab_Burge
09/04/09 04:32 AM
gregsdart
09/04/09 07:23 AM
440Jim
09/04/09 12:14 PM
B G Racing
09/04/09 12:23 PM
68roadrunner
09/05/09 02:39 PM
440Jim
09/05/09 02:58 PM
68roadrunner
09/06/09 03:04 PM
Cab_Burge
09/05/09 03:42 PM
sixpackbee
09/04/09 12:19 PM
