thanks for the input. I will mess with it some this weekend.
I will first check the fuel pressure and carb vaccumn, last I checked several months ago it was at 17-18 pounds of vacumn.
As far as the metering rods go...I just put them back in the way they came out...so I don't imagine it could be something like that.
I'll keep you posted. I am also going to ditch the double filter and just run one good one after the pump and see if that helps.
thanks.!
eight
Mopar or no car
