Got the front end off of it this weekend! Just have the cab left and will be scrapping the rest. Motor and trans are both locked up. The frame is bolted together right in front of the rear spring mounts and from there back it is only about 4" C channel, less than my 73 1/2 ton. I think I'm just going to swap it all out, did some measuring on a 95 Dodge Ram 3500, will have to move the motor back a bit, but looks like everything will fit good. I am already looking for a Ram 3500 frame with a cummins, man are they expensive, going to have to save a bit to get one that is worth taking.
If anyone needs any parts off this truck, other than the body let me know and I will see what shape it's in.
