Re: Achieving E body stock console texture????
[Re: DAYCLONA]
#448078
08/24/09 06:04 PM
08/24/09 06:04 PM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
Dave you might want to pick up a can of Rustoleums spray on bed liner, in a red/white spray can at AutoZone, about $4,....tough as nails, if you spray it with some distance, has a nice texture, just knock it down with sandpaper later, to slightly flatten the surface like whats on a stock E body console, or E body interior grain, then coat it with SEM's Landau Black to restore color....I just fabricated a radio delete plate, and happened apon the stuff experimenting with textured finishes,
Mike, thanks a ton, I will look for the stuff.
thanks again
I spent the day doing/ making this
Mike
