Yea it's a 70-72 A-body fender. The body line above the dent is bowed out a little. What do you mean by spooned? The upper body line is basically fine, maybe a 1" - 2" portion is raised. The lower line is damaged, it's a little better then where your line is drawn in, but it's rounded toward the front of the car.
