My balancer has spun about 8 degrees on my pump gas,internal balance,408" small block. The brand is Romac. When I went to adjust timing I discovered this.
Is this a big problem, other than setting timing?
What brand do you guys recommend? I need to bolt on the factory 70 Dart pulley.
