Heres an option... I need to go back and clean it up but not bad for a quicky job... The coil bracket is a piece of 1" 12ga flatbar with three holes drilled in it one for a manifold bolt & two for the std coil bracket...The fuel line is patterned after the stock sixpack & hemi style lines & fittings..
