I just double checked (5 mins ago) with a test light only two fuses on my 69 is hot with the key out and it is the dome light circuit and the tail lamp (brake light?).
Looking at the 68 RR wire schmactic I would pull power off one of the solid black wires (hot key on) leading to the fuse box and run a small fuse.
Is it possible you have something wired wrong?
I believe the black wire coming out of the ignition switch is switched power and feeds several fuses in the the fuse box.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
