Ok so I got the new pump on the car with reg. and plumbed it all, which didn't take much. It was pretty much a throw on, only had to change one fitting.. My question is that when I set the pressure I set it running and was at 6.5 lbs. I shut the car off and then had to start it later in the night and the pressure was a hair under 6 lbs .. why the change.. I'm going to re-set it tonight when I do the valves.
