Practically any Mopar from the early 60's through the late eighties... The Pitman shaft changed to a larger spline around 73, the large spline pitman arm is still available unlike the small spline that sells for big $$$ there are slight variations in the pressure fitting/hose but that is handled by transfering the original adapter that you no doubt sent in with your box....
