I have a return style regulator that is DOWNSTREAM of the carb and does not kill any of the flow going to the Carb. It is a BACKPRESSURE Regulator and may work for you.
That is exactly how I did mine and used a comp 140 with -08 pressure and return and I have no issues running 10.00@131.00
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
