Might get away with that C.R with magnums.But the original poster has a slightly domed piston (TRW 10.5) and open chamber heads.I have run the exact same set-up and detonation was a major factor.With that combo as the original poster stated backing off the timing will result in poor performance,get the timing where it needs to be and use a higher octane fuel.
