I was just over on the FBBO [For B Bodies Only] Board and a question was raised about taking a C Body Motor and installing it in a 69 Plymouth Satellite. Seems there are some problems with the steering linkage interfering with the Oil Pan. Reply was to swap out the C Body Oil Pan for a B Body Oil Pan and also a different Oil Pick Up unit. It was recommended to use the #402 Pan and Pick Up. If this is the case then my Motor Install is now going to be pushed back as funds are really limited right now and the hassle of draining out the Oil...already primed the Motor. It just never ceases to amaze my how when working on these old vehicles just how much info is omitted when it comes to this type of thing. Just cannot seem to get ahead on this project. Any advise or guidance would be appreciated along with the correct part numbers to make this swap work. Car was a 318 so the 383 install is not going to be an issue other than what I have just mentioned.....Thanks in advance MOPARTS
