Speaking from personal experience. Make an outline of the hump on the floor before you weld it in and just cut out that whole area leaving enough to weld to. You will need the area for clearance and if you leave an overhang it is just somewhere for junk (leaves,dirt,etc;) to sit and and cause corrosion.
