one pan leaks only in the back. What can I use to fix this *(&*^%) leak.
Lay the pan on a flat surface check for gaps between the pan and the flat surface. If the pan is bent straighten it. Look for leaks from up above where the fluid would run down on the pan. Check the gear selector shaft seal, Fill tube o-ring, cooler lines. There is pin in the back of the transmission under the tail shaft which has a o-ring on it. Mine was leaking real bad from the pin. I pulled the pan, cleaned the area up, put a little rtv on top of the pin and let it dry before filling the trans with atf. No more leak from the pin.
