If you can't get it to settle own for tunning, you may need to, "spring load" the carb's needles and seats. holley has a kit. dail it in to baseline, and you might not need it. but doesnt hurt.
Get an overflow bar , if its really shakin.
Then set the timming. Use a vacuum advance distributor with a extra 12* pulling idle vacuum @ manifold.
