My combo is also a 440 .30 over with 2355 slugs. I run a Hughes 572/579 solid with 272/279 @50 cam. I have indy ez's stck port heads with a eddy victor int. 3.91 gears with 28 M/T street radials. This cam idles nice with a pretty fast chop. I also run power brakes with this cam (couldnt believe it) All my susp is stock and I still managed a 11.49 @117mph with a 1.66 60ft.so far. Im sure theres more in it. I need to do some susp wrk. I did run a comp XE295hl (hyd flt cam)cam and it ran pretty well also with a mean idle. It just died after bout 5500 rpm so i went solid. Oh yea my stall is a 10'TCI 3500-3800 stall.
