I have lost my reverse in my 727 trans. It still has good pull in drive and low and will shift through the forward gears with no problem. It also has netural. When shifted into reverse nothing happens it does not drop the engine RPM or have any rear motion to the car. It was rebuilt about 300 miles ago but it has been over two years so I cannot carry it back to the builder. It is behind a mild 440 and does not see the strip. What could have blown out?
I also need a convertor recomendation. It will be for the 440 with a Comp extreme energy 268X cam and only see mild street action. What stall recomendations should I be running. The one in there now is locking up at idle.
David
