old PS is not like New PS. True but by simply swapping out the steering gear with a stage two or stage three from Firm Feel it can be... and what cam are you running???
Yep Low vacuum either to much cam or not properly turned... There are quite a few options including just tuning or a milder cam or adding an electric vacuum pump...
