i need the torque specs for the 6 bolts from flywheel/crank (bolts new from year one) also the 12 point bolts from around the edge for clutch/pressure plate wich is also new from year one
would you use semi perm locktite? (blue)
build up to the desired torque speck?
order of torqueing them?
thanks in advance ralph
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
