Troy,
Thanks, I'll be working on them tonight. Apparently the covers that were on there are not the original covers so it's hard to reverse engineer the new ones on. The bucket seat back covers slip over the seat backs and then the two ends should hog ring together. I made some listing wires out of coat hangers and sliped them into the pockets on the two ends. When I go to hog ring the two ends together the ring closes into a loop and the loop is actually bigger then the material and listing wires in it so it is a somewhat "loose" grip. I was expecting something of a tight grip and somewhat pulling and stretching of the cover. I may stop by the store tonight and pick up a larger diamiter rod to use and see if that helps.
