Pull the steering col connector apart(the one for the ts/brakes/flashers & jump 12V to the wire for the large filament in the rr dual filament bulb & if good pull the steering wheel & checkout the TS switch assy. If not good check the connector in the dr kick panel & if no "open" check the connector in the front part of the trunk for an "open", if good recheck the RR dual filament bulbs' socket
