My 440 with 12.5 turns like a /6 with the mini.Timing is 15 base.Mopar starters dont shim.Like said they dont make shims for them.Either your starter is bad or timming is off.Did you find TDC to make sure its only at 20?Dont trust the balancer marks.Rocky
Chrysler Firepower
