Anybody know the minimum thickness spec for the 70-71 B 2 pc rotors? I've got one that has never been turned I'm sure since it still had a pair of original KH marked pads and measured 1.002. The other side had replacement pads and was only .982. I sure hope the spec is not the .980 that I so far have run across.
