You probably have a bad place right in the harness between the fuse box and the two switches. First thing to do is take a good look right around the fuse box, otherwise, I'm afraid untaping the harness is the deal. Take a GOOD look at it's routing/ hanging: IS there any sharp corners, like stretched around a sharp corner, etc?
