i want to bolt this trans behind my 318. after some research i found i will need the flywheel from the donor truck, and it uses a different clutch than the 10.5" 833. it uses the same pilot bushing PN as the 833 so i guess bolting it up wont be a problem. does anyone know if a 727/4 speed or 904/3 speed slip yoke will fit this trans?
the 318 is just a stock rebuild w/ 340 cam, windage tray, perf. intake and holley 450 so im not making a ton of HP i think this trans should hold up behind it. what do you think? going in my 47 desoto.
