My tire looked like SSracers at anything less than 13.5. Mickey Tire rep was at classic and told me to stay at 13-14 psi
We looked at track photo guys pics and my tire was wadded up bad when PSI was in the 12's
Take a look at the track photo guys starting line shots. The guy even zoomed in on tire you can get a good idea from his pictures what the car is doing.
From the initial hits, it seemed to like about 13 lbs. Going back out tomorrow night to test some more. Vac pump hooked up, oil changed, air shifter connected, shifter adjusted to 8000 RPM, 2 step turned up to 6000, 1/4 more turn preload on pass side caltrac bar, 2 more jet sizes all 4 corners.....should make for an interesting night!
