You smack the side of the centerlink. The shock will break the taper loose. Put the castle nuts backward over the threaded taper ends to protect the threads and protect the castle slots on the bolts. That will give you a bigger target to hit.
But whack the sides of the centerlink ends HARD and at different angles to shock it loose. Pressure from a pickle fork helps, but like you said will mess up the boots.
