You can use compressed air to open the secondaries with the carb on the bench, if it'll make your troubleshooting go any easier. You'll see a tiny tube in the pass side primary venturi that passes to the vac sec pod. Just blast some air past that tube and the secondaries will pop open if eveything is working properly.
