Stay away from the 2 1/8" Hookers if you have heads with raised exhaust ports. I made mine fit but had to modify 2 tubes on the left side. My mottor is on a plate so I could put it where ever I wanted. They still wouldn't make it. I had to twist the #1 tube to miss the steering shaft. Doug
